residentevil35
Aug 03, 2015Initiate
Cannot connect WNDA4100 with Windows 10!!!
I just upgraded to Windows 10 about 2 days ago and as soon as I upgraded, my WNDA4100 Network Adapter quit working. The LED's no longer light up when it is plugged in. I went to netgear's website and...
- Aug 06, 2015
I just updated to Windows10 and had a similar problem (driver works, but could not connect to 5Ghz). I dug through forums and found similar problems to mine (and possibly yours?).
This link has a nifty quick-fix, and possible reason as to why you are experiencing this problem.
http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/wnda4100-loses-5ghz-after-81-update/d7ea4ec7-d60c-4216-b611-b6803324897e?auth=1
If you don't want to read through it, I'll quote the specifics here:"Hey there,
I encountered this exact same problem this morning - I ended up finding a way around it after some research.
- Press the Windows + X key, then select "Device Manager" from the menu in the lower-left hand corner of your screen.
- Find your Netgear WNDA4100 adapter under "Network adapters." Right click it and select "Update Driver Software..."
- Select "Browse my computer for driver software."
- Click "Let me pick..."
- You should see one driver from Microsoft and one from Netgear. Select the one from Netgear, click Next, and follow the installation prompts.
If you do not see the driver from Netgear, navigate to their support site and download the standard Windows 8 driver. After installation, you should see both.
For whatever reason, 8.1 defaults to the Microsoft driver. After enabling the Netgear driver, you should have full access to the 5GHz band.
Hope this helps!"
With windows 10, this worked for me, only there's a few differences in the steps that I'll outline here,
For the list of drivers, you should see a few drivers listed for your netgear adapter, next to them will be little certificates. You should see at least one that says "NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter (NETGEAR Inc.)" Select this driver (I had 2 listed, so I used the topmost listed) and finish the install process. This should reset your adapter driver and allow you to connect to either of your networks using the genie software.
I hope this helps, as I am glad it fixed mine.
MrJon
Aug 06, 2015Initiate
"Hey there,
Hope this helps!"
- residentevil35Aug 08, 2015Initiate
Ahhhhhh thank you so much, that was the easiest thing to do!
- Joslaveman1Aug 10, 2015Initiate
U r a genius!!!!! I had the same problem when updating to Win 10. I followed your directions and now have 5ghz frequency up and running....
Thank You
- mikecharlie57Aug 19, 2015Initiate
Just the ticket! I followed your instructions, specifically the details in your note at the end, and it worked like a dream! Thanks for this .... much appreciated.
- bing1377Sep 11, 2015Tutor
Well I have the exact problem but when doing your fix the Yellow exclamation mark disappears but after taking minutes it says that "This operation returned because the timeout period expired."
Still no lights on dongle. Still not detectable by genie.
I have 4 drivers listed and tried all of the 3 netgear ones and get the timeout with all.- JamesGLSep 15, 2015NETGEAR Employee Retired
Hi bing1377,
Welcome to Community!
You can follow the steps given in the KB article below. Please take note of some steps you may need to do when you have a USB 3.0 as it might be the problem.
note: Please disregard the A6210 drivers and use the WNDA4100 drivers that you have.
JamesGL
Community Team
- bing1377Sep 15, 2015Tutor
No tried all that and it didn't work.
Still no lights on wireless dongle. Even tried my older VN111v2 and they wont work either.
Comes up with right name in Device manager but with yellow exclamation mark, try to change the driver and get error 39 as they will just not load.
Still cannot detect adapter with genie. Downloaded what Netgear say is Windows 10
Even tried rolling back USB 3.0 drivers as the one on there now looks new but nothing.
- cintron2861Nov 06, 2015Aspirant
Please remember to uninstall the Netgear Driver from the programs on the computer (device manager). Pull your adapter off, shut down, re-install your adapter after restart and then go to device mgr/ update/ select browse my computer/ let me pick/ select Netgear Driver from the list.
