hmatt415
Mar 19, 2016Follower
Does the "NETGEAR A6210 WiFi USB Adapter" support Miracast?
So I recently purchased a Microsoft Display adapter for my television. The hope was to screenshare my computer to my tv. Simply right? Well turns out when I go to Notification Center -> Connect on my...
mondenath
Jul 23, 2016Prodigy
Miracast works if your routers support. Say it can be configured via ad-hoc or infrastructure mode. Try connecting via router so that it could work if ad hoc fails
- JamesGLJul 27, 2016NETGEAR Employee Retired
Hi hmatt415 and kidmicro,
The adapter does not supports Miracast, The only NETGEAR device that supports miracast is the PTV3000 which is EoL already but for Wireless adapters, none of the it works with Miracast.
- mondenathAug 04, 2016Prodigy
I do see that. But DLNA works out of box even to stream to Chromecast works flawlessly.
if you are trying to project taken camera video or internal video try using some casting media player like cyberlink power dvd 16. - RussellJJan 17, 2017Aspirant
About 6 months ago, NETGEAR Moderator JamesGL said (re: the "NETGEAR A6210 WiFi USB Adapter"):
> The adapter does not supports Miracast.
> The only NETGEAR device that supports miracast is the PTV3000 which is EoL (End-of-Life) already,
> but for Wireless adapters, none of them works with Miracast.
Is that ("none of them works with Miracast") still the case?
Thanks.- JamesGLJan 18, 2017NETGEAR Employee Retired
Hi RussellJ,
Still the same. No NETGEAR adapter supports Miracast except the PTV3000.
