hmatt415
Mar 19, 2016Follower
Does the "NETGEAR A6210 WiFi USB Adapter" support Miracast?
So I recently purchased a Microsoft Display adapter for my television. The hope was to screenshare my computer to my tv. Simply right? Well turns out when I go to Notification Center -> Connect on my...
JamesGL
Jul 27, 2016NETGEAR Employee Retired
Hi hmatt415 and kidmicro,
The adapter does not supports Miracast, The only NETGEAR device that supports miracast is the PTV3000 which is EoL already but for Wireless adapters, none of the it works with Miracast.
mondenath
Aug 04, 2016Prodigy
I do see that. But DLNA works out of box even to stream to Chromecast works flawlessly.
if you are trying to project taken camera video or internal video try using some casting media player like cyberlink power dvd 16.
