Olegrius's avatar
Olegrius
Don't connect 1300 Mbit/s 802.11ac
Hello!
Windows 7 64bit Ultimate, router R6300 (last update).
I can't connect to the 5GHz with A6200 when in the spped settings of router is 1300 Mbit/s. Status of IPv4 - no internet access, IPv6 - no network access.
But I can connect to the 5GHz with any speed in settings from mobile phone or notebook with 802.11n support.
And but I can connect to the 5GHz with A6200 when in the settings of router is 289 Mbit/s or 600 Mbit/s. But, status of IPv6 - no network access, but all work.
Please, HEEELP! I need 5GHz with 1300 Mbit/s.
PS
I do not have Windows 8, I like Windows 7.
  • It seems I solve the problem.
    I set up 5 GHz netowork to 600 Mbit/s, and connect ro ir normally.
    Then I turn on the Guest (5 GHz) network, and connect to it. The connection was successful.
    From the Guest (5 GHz) network I change ro 1300 Mbit/s and after that I can connect to it.
    May be this way will be helpful to you, too.
