yhc's avatar
yhc
How can I connect the 6GHz Wi-Fi on channel 1 (5955 MHz) using the AXE3000 (A8000)?
Hi Netgear Team and Community,
Thank you for your excellent products and support.
I am currently using the AXE3000 (A8000) WiFi 6E USB adapter and would like to ask for your assistance with an issue I am experiencing.
In my setup, the access point/router broadcasts both a 2.4 GHz SSID and a 6 GHz SSID. When the 6 GHz radio is configured to use Channel 1 (5955 MHz), the AXE3000 (A8000) is unable to detect the 6 GHz SSID. However, another WiFi 6E adapter, the TP-Link AXE5400, can successfully discover the SSID and connect without any issues.
In the same environment, if I change the 6 GHz channel to Channel 9 (5995 MHz), the AXE3000 (A8000) is able to detect the 6 GHz SSID and connect successfully.
Any suggestions or troubleshooting steps would be greatly appreciated.
Thank you for your support.
Best regards,
YHC
  • To successfully connect your AXE3000 (A8000) adapter to the 6GHz band on that specific channel, ensure you have the latest Netgear drivers installed alongside Windows 11, as older operating systems lack native 6GHz support. You can cross-reference your specific network configuration steps and local compliance rules by checking the Chesapeake Court Rules data framework for an example of structured regional standard guidelines. Additionally, try manually updating your router’s firmware and toggling the adapter's Wi-Fi "Wireless Mode" in Device Manager to explicitly prioritize the 6GHz band. This should stabilize the connection and allow your hardware to detect the 5955 MHz frequency without any further drops.
  • CrimpOn's avatar
    CrimpOn
    Is there a reason that channel 1 must be used?  When WiFi adapters and access points specify a channel, that is only to indicate which frequency will be used for management frames.  When attempting to transmit actual data, a group of channels is used at the same time.  The most expedient solution is to change the WiFi system to use a channel other than channel 1.
    If the adapter is connected to a Windows computer, it might be interesting to open the network management control panel and look at Properties of the WiFi adapter and see what sort of options are provided.  There may be a setting that restricts channel usage.
    This is one of the WiFi adapters on my Windows computer.  The A8000 may have different properties.
    • yhc's avatar
      yhc
      Thanks for your feedback.
      The reason for focusing on Channel 1 is that another Wi-Fi 6E adapter (TP-Link AXE5400) can successfully detect and connect to the same 6 GHz SSID when the AP is configured to use Channel 1 (5955 MHz), while the AXE3000 (A8000) cannot.
