chuey1311
May 23, 2017Aspirant
N-3100 Error Message
When installing Wireless adapter, I get an error message (Sup Tools) (0x00000057) Is there another driver to install that I am able to put on a CD & install on my PC? or am I doing something wrong.
- William10aMaster
Which wireless adaptor are trying to install?
- chuey1311Aspirant
Its the Model WNA3100 USB connection
- JamesGLNETGEAR Employee Retired
Hi chuey1311,
You can download the drivers here.
https://www.netgear.com/support/product/WNA3100.aspx#download
- chuey1311Aspirant
Crosses fingers, I will keep you updated.
- chuey1311Aspirant
No dice James. still getting same error message (error (0x000000557) Pretty much as this point my patience have run out for this product, I need to return & maybe get something a little better.
Hi chuey1311,
Try to install it on a different computer and check if the same issue.
- chuey1311Aspirant
Actually I got rid of it. One I was not told that wireless adapter does not work on windows 8.1 but it does work on windows 10. I will not be buying any product from Netgear EVER again. Thanks bud
