jordarn
Jun 20, 2018Tutor
Netgear A6210 adapter not found
Yesterday a Netgear Genie dialog box popped up on my Windows 10 PC and it automatically downloaded an update. I clicked install and now my A6210 adapter no longer works. No lights come on on the devi...
michaelkenward
Jun 21, 2018Guru - Experienced User
What was the download that you clicked? Something from Netgear? A Microsoft Windows update?
Do you have a Windows restore point that you can revert to that predates the update?
jordarn
Jun 21, 2018Tutor
I do not have a rollback in Windows. I updated my copy of Windows 10 a few weeks ago but had no issues. I believe the driver update started automatically through the Netgear Genie application. It downloaded itself and then asked if I wanted to install the update. I did and then it had me restart my computer. That was when it stopped working.
- michaelkenwardJun 21, 2018Guru - Experienced User
Unless you have disabled this feature, Windows keeps regular Restore Points – this is not the same as a full system image – not just when Windows updates. Mine currently go back a couple of weeks.
They will get wiped out if you keep doing stuff.
I didn't know that USB adapters came with that horrible feature. It is something that newer routers offer, but I turn it off.
- jordarnJun 21, 2018Tutor
Thanks I will have to take a look at that later. I have already ordered a replacement (D-Link AC1900) but I might return it if I can get this Netgear one to work again
Have you looked in Windows device manager for "hidden devices"?
They are invisible by default. Get Windows to display them and then removing the device completely from the USB section forces your PC to forget it completely so that you can reinstall from scratch.
One thing that other people have also reported is that they don't need any Netgear software or drivers to get their adapters to work. These things all use the same chips and Windows has support built in.
