lukedukeb
Mar 26, 2017Aspirant
NETGEAR A6210 is not found?
I am currently using a windows 10 pc and just this bought this adapter 3 days ago and arrived yesterday. i was setting it up today, so i go ahead and put in the cd and then click setup and it begins ...
- Mar 30, 2017
Hi lukedukeb,
Please use this driver.
https://kb.netgear.com/000037991/A6210-Software-Version-1-0-0-36?cid=wmt_netgear_organic
drjack
Jul 27, 2017Aspirant
I have a Tivo Roamio connected to an HD antenna in my home office (not connected to cable in the rest of the house). I've purchased a Netgear A6210 recommended by Best Buy to connect Tivo to my wifi router. I've run the installation CD, also installed latest drivers from Netgear downloads. No light on adapter and I keep seeing "Netgear adapter not found."
I next plugged the new adapter into usb on my computer. Same result. I have a different Netgear adapter on that same PC (router is 70' away) and my wifi connection is fine for my PC. But no joy with the Tivo. Any suggestions? Did I get the wrong type of adapter?
JamesGL
Aug 02, 2017NETGEAR Employee Retired
Hi drjack,
The adapter only works with Windows based OS computer. It may not be compatible with your TiVo.
- drjackAug 02, 2017Aspirant
That's helpful. Thanks. So I've now installed it on my computer in place of the small Netgear adapter.
Is there a Tivo compatible Netgear adapter?
- JamesGLAug 07, 2017NETGEAR Employee Retired
Hi drjack,
If the TiVo has ethernet port, you may try checking WNCE3001 or WNCE4004.
- JamesGLAug 13, 2017NETGEAR Employee Retired
Hi drjack,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
