Dickie543
May 23, 2017Aspirant
Netgear AC1200 USB WiFi Adaptor
Can I move the AC1200 WiFi USB adapter between two computers until I get to a store and buy a second WiFi adapter? It is an hour drive one way, I work in the other direction, and there is just no ti...
- May 29, 2017
Hi Dickie543,
You can install the adapter on a different computer. You can visit support site for the driver.
https://www.netgear.com/support/product/A6210.aspx#download
If you purchase the same model, no need to reinstall the driver.
JamesGL
May 29, 2017NETGEAR Employee Retired
Hi Dickie543,
