Dickie543
May 23, 2017Aspirant
Netgear AC1200 USB WiFi Adaptor
Can I move the AC1200 WiFi USB adapter between two computers until I get to a store and buy a second WiFi adapter? It is an hour drive one way, I work in the other direction, and there is just no ti...
- May 29, 2017
Hi Dickie543,
You can install the adapter on a different computer. You can visit support site for the driver.
https://www.netgear.com/support/product/A6210.aspx#download
If you purchase the same model, no need to reinstall the driver.
JamesGL
May 29, 2017NETGEAR Employee Retired
Hi Dickie543,
JamesGL
Jun 04, 2017NETGEAR Employee Retired
Hi Dickie543,
You are welcome. I am glad I was able to help.
