porkbucket's avatar
porkbucket
Netgear AC1750 and Tivo Roamio: TCP OUTGOING PORTS REPORTED AS BLOCKED
HI, I'm hoping that somebody can kindly help:
Netgear AC1750 and Tivo Roamio (no internet/trouble with router)
TIVO CONNECTS TO MOCA BUT NOT ROUTER/INTERNET
For no apparent reason, our TiVo Roamio Plus (which has been activly working on our home network, no longer connects to the internet. Under the Tivo setting, I get an IP address but no DNS assignment when trying to connect TiVo to the network. Tivo error messages says "trouble with router", "no internet connection", "TCP failure requires the following ports to be opened": TCP port 37, 80, 7288,
7287, 8080, 8081, and 5223.
Cox says 80 is blocked by them for security, but that's only for incomming and all other ports should be OK to open. So far I have tried talking to TiVo, Cox and NetGear support, but none can help.
MODEM: Motorola MB8600 Cable Modem
ROUTER: Netgear AC1750 Smart WiFi Router
MEDIA DEVICE: TiVo Roamio Plus
TIVO TO ROUTER CONNECTION: Ethernet Cable
ISP TO TIVO/TUNER (with cablecard) CONNECTION: Coax/MOCA
ISP INTERNET PROVIDER: Cox Cable
TIVO IP ADDRESS: 169.254.176.43
TCP OUTGOING PORTS REPORTED AS BLOCKED:
37, 80, 7288, 7287, 8080, 8081, 5223
CURRENT STATUS:
- NO PORTS ARE CLOSED IN ROUTER SETTINGS
- NO PORTS CLOSED IN PC FIREWALL SETTINGS
- YET ROUTER DOES NOT SHOW TIVO UNDER CONNECTED DEVICES
WHAT I HAVE DONE:
- SWITCHED OUT THE TUNER
- CHANGED ETHERNET CABLE ROUTER PORT
- DOUBLE CHECK ROUTER SETTING
WHAT I HAVEN'T DONE:
- RESET ROUTER
- RESET TIVO
1 Reply
  • SOLVED
    Turned out to be a bad ethernet cable causing the issues.
