TechKitten
Apr 30, 2016Aspirant
Netgear AC600 not working, no detection in setup.
So, I went to format my Dell Latitude D800, back to XPSP3 from Vista SP2, and the WiFi card (AC600) was picked up previously during setup (and no, the USB port is not faulty) and it is not picked up...
- May 07, 2016
UPDATE: I have gotten it working, I just needed to reformat the PC. :mantongue: TIP: Just UNPLUG the adapter during Windows setup.
TechKitten
May 07, 2016Aspirant
- VE6CGXMay 07, 2016Master
I think you meant Windows installation or upgrade from XP to Vista. I never heard formatting OS I think the driver for that USB was the problem. General rule, you always check driver compatibility when moving OS from one version to another one like you just did.
- TechKittenMay 10, 2016Aspirant
The driver wasn't at fault, it was the USB thingy.
- VE6CGXMay 10, 2016Master
How do you format the PC? It is always known when you change OS, you have let the new OS discover and learn the device. Nothing new.
I guess you don't live in North America.
- TechKittenJun 07, 2016Aspirant
Q: How do you format the PC?
A: Reinstall the OS
It is always known when you change OS, you have let the new OS discover and learn the device. Nothing new.- I knew that.
I guess you don't live in North America.- Yes, I do, I live in the USA
- VE6CGXJun 07, 2016Master
Then what seems to be the problem? By unplug/plug the USB adapter, you made the new OS learn that thingy. What's new about this?
Going from XP to Vista what do you gain?
