TechKitten
Apr 30, 2016Aspirant
Netgear AC600 not working, no detection in setup.
So, I went to format my Dell Latitude D800, back to XPSP3 from Vista SP2, and the WiFi card (AC600) was picked up previously during setup (and no, the USB port is not faulty) and it is not picked up...
- May 07, 2016
UPDATE: I have gotten it working, I just needed to reformat the PC. :mantongue: TIP: Just UNPLUG the adapter during Windows setup.
TechKitten
May 07, 2016Aspirant
VE6CGX
May 07, 2016Master
I think you meant Windows installation or upgrade from XP to Vista. I never heard formatting OS I think the driver for that USB was the problem. General rule, you always check driver compatibility when moving OS from one version to another one like you just did.
