Hxllxws
Mar 23, 2016Follower
Netgear n300 usb adapter doesnt work..
So i recently built a computer and i know everything works fine. Ask for specs if you need them but anyway whats important is this adapter. This is my second one. Both have done the same thing to me. ...
Jeanine100
Apr 01, 2016Aspirant
Hi I have the same problem
- AdapterHelpApr 02, 2016Aspirant
I am aslo experiencing the same issue. Could this be related to a bad update?
- JamesGLApr 10, 2016NETGEAR Employee Retired
Hi All,
Have you tried my suggestions on my previous post? If not yet, please try it and also try to install it on a different computer.
- JamesGLApr 13, 2016NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
