Hxllxws
Mar 23, 2016Follower
Netgear n300 usb adapter doesnt work..
So i recently built a computer and i know everything works fine. Ask for specs if you need them but anyway whats important is this adapter. This is my second one. Both have done the same thing to me. ...
nicho1981
May 07, 2016Aspirant
WNA3100M driver will not install on my win 10 x64 pc. It hangs with 0%cpu usage.
- JamesGLMay 26, 2016NETGEAR Employee Retired
Hi nicho1981,
Is this the software version you used to configure the adapter?
http://kb.netgear.com/app/answers/detail/a_id/30154?cid=gwmng
- JamesGLMay 30, 2016NETGEAR Employee Retired
Hi nicho1981,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
