DanT2590
Mar 24, 2016Tutor
Netgear program won't run
About 2 weeks ago, my Netgear WNDA3100 v2 quit working. I'm using it with my laptop so I can connect to the faster wireless network. It worked fine until a few weeks ago, and I would find the compute...
JamesGL
Mar 27, 2016NETGEAR Employee Retired
Hi DanT2590,
What is the driver version you have used to install the adapter on your Windows 10? When installing the adapter, please disabled the antivirus software for the mean time then enabled it after the installation.
