Mkveli2pac's avatar
Mkveli2pac
NetGear wnda 3100v2 connections issues since Windows 10
Ever since I downloaded Windows 10, my wnda 3100v2 adapter loses connection randomly.  I have download the latest firmware and it has not solved the problem.  When the connection goes out, the adapter finds no connections available and the only way I can get a connection again is by removing the adapter and plugging it back in.
I know the latest firmware states it is Windows 10 compatible but I never had a problem with this adapter when I had Windows 7.
Any help would be appreicated.
Thanks
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Mkveli2pac,
    Welcome to Community!
    Have you tried installing the standalone driver instead of the driver with the Genie?
    JamesGL
    Community Team
    • BaJohn's avatar
      BaJohn
      Virtuoso
      I have the same adapter and the same problems.
      The standalone driver has a higher (later) version, but in my case just makes the problem worse.
      It is listed as 2.2.06 not 2.2.05 which is kinda weird, as it is a Zip for 2.2.0.5?
      • BaJohn's avatar
        BaJohn
        Virtuoso
        MKveli2pac
        Please just to satisfy my curiosity, can you start up a DOS session.
        Right click <Start> and choose command prompt (admin).
        Then type "netcfg -s n" and under the Network Adapters copy and paste the info here.
        It will probably, on a good system be 2 or 3 items/lines.
        Should take about 1 minute tops.
        Thanks
  • JamesGL, thanks for the welcome and yes I did download the stand alone driver and my results are the same.
    BaJohn I will try that when I get home tonight and let you know. Thanks guys.
  • Well, that escalated quickly.  Shortly after I made the post that I thought my problem was solved by JamesGL, guess what happened?  Yep, lost connection yet again.  Back to square one.
