KTSong
Feb 28, 2017Aspirant
Netgear WNDA4100 N900 Frequently Disconnects
Hello, I have Window 8.1. I use The Netgear WNDA4100 N900 Adapter. It frequently disconnects and looses its signal. All other wifi devices in the house run well. My computer is the only one that...
KTSong
Mar 04, 2017Aspirant
Sorry. I am having trouble getting my connection to load the page. I am answering you from my phone (that's how bad it is). I'm not sure how to get this update now...
aalexandrebeta
Mar 06, 2017Master
Sure when you are avalable fire up!
- KTSongMar 06, 2017Aspirant
OK. I tried it. It did not work. Still disconnecting from the internet...
- aalexandrebetaMar 06, 2017Master
Do you have an old usb adapter to check witch fault is it. Can you try the WNDA4100 on another laptop with different OS?
- KTSongMar 08, 2017Aspirant
I have an outdated Macbook Pro. I do not know if the adapter will work on it. The Macbook has built in wifi connectivity.
