KTSong
Feb 28, 2017Aspirant
Netgear WNDA4100 N900 Frequently Disconnects
Hello, I have Window 8.1. I use The Netgear WNDA4100 N900 Adapter. It frequently disconnects and looses its signal. All other wifi devices in the house run well. My computer is the only one that...
aalexandrebeta
Mar 06, 2017Master
Sure when you are avalable fire up!
KTSong
Mar 06, 2017Aspirant
OK. I tried it. It did not work. Still disconnecting from the internet...
- aalexandrebetaMar 06, 2017Master
Do you have an old usb adapter to check witch fault is it. Can you try the WNDA4100 on another laptop with different OS?
- KTSongMar 08, 2017Aspirant
I have an outdated Macbook Pro. I do not know if the adapter will work on it. The Macbook has built in wifi connectivity.
- aalexandrebetaMar 08, 2017Master
KTSong OUPS I can't help you with your issue on your Mac devices, I am a total "moron" if mods allow my french in that area.
I will missdirect you :(!!
But you can check on the support website and check if the driver works with your antique device.
How old is your Mac?
I own a 17 y/o Dell dimension with nearly all parts still working from the purchase date apart of the HDD and 3 sets of screen! 1900 days continuous connection to emule!!!
Regards from FrogLand!
Where are you from?
