ScottCahill
Jul 08, 2018Aspirant
Network adaptor not found A6100 WiFi adaptor
I cannot figure this out. The crazy thing is, I bought an A6100 WiFi USB adapter and got it to work. I downloaded from the disc, found my network, and was online. My mistake was updating the software. I’ve been stuck for 2 hours since then. I guess rtwlanu_XP.sys is not found. I click it on the cd rom, I click the Netgear file nothing. It thinks forever and says file not found. If I click next on the genie dialog box, it thinks for 10 minutes and says adapter not found.
i found a similar post:
But their answer in photos says to manually instal driver via device manager. I can’t find that on my computer. It’s an older os and I’m not very good with networking. I did restart. I reinstalled. I’ve uninstalled then reinstalled. About to give up but help would be appreciated.
- ScottCahillAspirant
An update, I did find device manager but no matter what I do, it asks for rtwlanu_XP.sys. Maybe I need to download this on another computer and put it on mine via a thumb drive? Not sure if this is some file that is widely used and I can find it on the internet.
- LukeqtnzAspirantI have experienced the exact same issue when following the software update. Does anyone please have any advice how to resolve this?
- LukeqtnzAspirantScott, have you had any assistance with this at all or managed to resolve the issue?
Good news, I figured it out two days later.
i downloaded the rtwlanu_XP.sys file from:
https://www.pconlife.com/download/otherfile/76637/c6cde470bdea5f41414220e024ce4765/
Enter the captcha and save. My next problem was I was saving the file in C:Windows/sys32/drivers or whatever it is, that doesn’t work. You have to save it right where that error box was looking:
C:program files\netgear\A6100\driver
Maybe a restart and I was golden. It asked if I wanted to update and I said no way, it’s working I’m not messing. Not bad for someone who hates routers and all. Good luck.
