loredallatorre's avatar
Apr 21, 2017
problem with wireless adapter WG111v3
Yesterday, after an unlucky fall, my MacBook Pro's wifi integrated hardware broke. By the way I realized that I've a wifi adapter somewhere, found it, I've tried to connet it to my MacBook, I've download the driver from here -  http://www.netgear.it/support/product/WG111v3.aspx?cid=wmt_netgear_organic#CompatibilityandAddingDevices_CommonTopics - the description sais "OSx 10.5", I've 10.10 and after had installed the driver, it doesen't work. Does the adapter's really compatible with Mac ? Do I have to find another driver ? Thank you
  • Hi loredallatorre,
    It is only compatible with 10.5 no more updates for latest version of OSX.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi loredallatorre,
    • JamesGL's avatar
      JamesGL
      Hi loredallatorre,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
