  • Security key is created when you configure the router or it is default value if you did not change it. On the router at wireless config. page.
    If you want to connect adapter either you have tyo enter the key yourself when asked during set up session or use WPS if it is available.
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi irishdude,
      Contact your routers brand to get the security key of your wireless network.
      • VE6CGX's avatar
        VE6CGX
        Master
        Wait a minute, why OP has to ask manufacturer for security key? There may be a default one but user can change anyway he wants per security protocol.
