irishdude
Jun 24, 2016Follower
Security Key Location
Where can I get the security key?
- VE6CGXMaster
Security key is created when you configure the router or it is default value if you did not change it. On the router at wireless config. page.
If you want to connect adapter either you have tyo enter the key yourself when asked during set up session or use WPS if it is available.
