parveen's avatar
parveen
Follower
Oct 21, 2015
USB WIFI Adapter for android
Hi All,
I want a USB based wifi Adapter that is supported on Android platform. I am working on Netgear wna1000M Adapter which is based on realtek 8192cu chip.
Can you guys suggest me any other adapter with higher GAIN like netgear AC1200.
The adapter should be based on rtl8192cu.
Or if it is on any other chipset can i have a driver for the same to integrate in my AAndroid image.
1 Reply
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi parveen,
    Welcome to Community!
    NETGEAR adapters works with Windows based Operating Systems. For now, no adapters that will work with Android platform.
    JamesGL
    Community Team
