eraahad
Jan 02, 2017Aspirant
WG311T Installed on Windows XP
Yes the PCI adapter is available in device manager and works correctly according to it. The troubleshooting button does not work, it is pointing to Window XP Home edition which does not work.
The Netgear Smart wizard is running and the adapter is visible there as well. The security is WPA-PSK [AES]. When applying the code it is Scanning without any connection to any channel and does not detect any signal.
The laptop on which I am writing this on is connected to the same wireless network without any problem.
Below you found the previous conversation, which I had no possibly to evaluate since the PC was disconnected.
What other Ideas do you have?
English / NETGEAR / Home Networking / WiFi Adapters / Re: WG311T XP Join Now|Log In|Help
WiFi Adapters
Search for answers...
Can't find what you're looking for? Start a New Discussion
New to the community? Start Here
This topic has been marked solved and closed to new posts due to inactivity. We hope you'll join the conversation by posting to an open topic or starting a new one.
Topic Options
« Message Listing
« Previous Topic
Next Topic »
eraahad Follower
Follower
eraahad
Accepted Solution WG311T XP
Options
2016-11-09 02:24 AM
After done a number of 67 updates on my XP the wireless adapter can not connect, not even will the Wizzard starting up. I have taken the latest version of SW from your page. I have tried to use HW detection of XP without any success. The instruction on https://kb.netgear.com/app/answers/detail/a_id/18586#?cid=wmt_netgear_organic does not help. It worked well before I did the security updates of XP.
Solved! Go to Solution.
Report Inappropriate Content
Message 1 of 3 (239 Views)
Labels: Troubleshooting
0
Accepted Solutions
JamesGL NETGEAR Moderator
NETGEAR Moderator
JamesGL
Re: WG311T XP
Options
2016-11-15 06:05 PM
Hi eraahad,
Can you still detect the adapter under the device manager? If not, you might need to unplug and replug the adapter. Try disabling firewall or antivirus while installing the adapter.
JamesGL
Community Team
Message 2 of 3 (383 Views)
0
All Replies
NETGEAR Moderator
JamesGL
Re: WG311T XP
Options
2016-11-15 06:05 PM
Hi eraahad,
JamesGL
Community Team
Message 2 of 3 (384 Views)
0
NETGEAR Moderator
JamesGL
Re: WG311T XP
Options
2016-11-20 05:43 PM
Hi eraahad,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Message 3 of 3 (183 Views)
0
« Message Listing
« Previous Topic
Next Topic »
Discussion Stats
2016-11-09 02:24 AM
0 kudos
2 in conversation
Recommendations
There are no new messages in this topicSolved! XPS Button Nighthawk D-7800
There are no new messages in this topic DGN1000 and WG311T problem and solution
There are no new messages in this topic Ac791L windows xp Drivers
There are no new messages in this topic Dell XPS 17 crash.
There are no new messages in this topic Windows XP/PS3 home edition
PAT-ADAMA
Powered by Lithium
© 1996-2017 NETGEAR®
Privacy Policy LEGAL DISCLAIMER TERMS OF SERVICE
Twitter
Facebook
Youtube
- JamesGLNETGEAR Employee Retired
Hi eraahad,
Try changing the security to WEP as the device may not support the WPA.
