Ashwin5171's avatar
Ashwin5171
WN111v2 Usb adapter | Windows 7 pro problems
Hello my name is Ashwin. I have had a WN111v2 for a long time and it has served me faithfully. Unfortunatly when I was running a deepscan to find viruses my father walked into the room and hit the master power button on my power strip, which cut off all power to my computer. This damaged some of my program files so next morning I turned it on and let it go into startup repair, unfortunatly Microsoft pegged me with the accusation of having counterfeit software even though I have bought it legally. Worst of all, my WN111v2 wont connect to the internet, it just keeps "Identifying" the network and won't ever connect.
PLEASE HELP!!!
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Ashwin5171,
    Welcome to Community!
    I would suggest uninstalling and reinstalling the adapter. You can go to support.netgear.com for the driver of the your adapter.
    JamesGL
    Community Team
    • Ashwin5171's avatar
      Ashwin5171
      Hey James I already tried that, but it still did not work anyother suggestions?
      • JamesGL's avatar
        JamesGL
        Ashwin5171,
        You may try to install it on a different computer to isolate if the problem is with the adapter.
        JamesGL
        Community Team
