Handstand
Apr 15, 2018Aspirant
WNA 3100 Adapter Windows 10 Pro Failure
I understand that there is an issue with detecting the USB adapter when on Windows 10 during the installation which has been solved. I just finished building my PC and currently using Windows 10 Pr...
michaelkenward
Apr 16, 2018Guru - Experienced User
I assume that you have tried the latest software for your device:
WNA3100 (N300) Wireless USB Adapter Support | NETGEAR
Some people find that they do not need any software or drivers. They just use the stuff that comes in Windows 10.
Handstand
Apr 16, 2018Aspirant
I can’t download that as I don’t have WiFi on my PC and only limited to the CD I was given.
- michaelkenwardApr 16, 2018Guru - Experienced User
You have access to the internet, or you would not be here.
Have you tried to download the file to whatever you use to get here? Then put it on a USB drive and load from that.
- HandstandApr 16, 2018AspirantYes, I have internet which is why I’m here on my Phone, but not on my PC.
I did try to download the link on a MacBook but it wasn’t compatible as it’s Apple.- michaelkenwardApr 16, 2018Guru - Experienced User
It should be possible to download any file regardless of the operating system. I can retrieve Windows files in Android.
