Handstand
Apr 15, 2018Aspirant
WNA 3100 Adapter Windows 10 Pro Failure
I understand that there is an issue with detecting the USB adapter when on Windows 10 during the installation which has been solved. I just finished building my PC and currently using Windows 10 Pr...
Handstand
Apr 16, 2018Aspirant
I can’t download that as I don’t have WiFi on my PC and only limited to the CD I was given.
michaelkenward
Apr 16, 2018Guru - Experienced User
You have access to the internet, or you would not be here.
Have you tried to download the file to whatever you use to get here? Then put it on a USB drive and load from that.
