albert1946's avatar
albert1946
WNA 3100 Wifi adapter with windows 10 operation system
Hi
I have problems with the Netgear USB adapter WNA 3100 with windows 10, after 2 or 3 days I have no connection to the router.After reinstalling it works for 2 or 3 days !!
Windows trouble shooting says, there is a problem with the USB driver !!
My installed software are Netgear Genie 2..2.0.4 and driver 5.100.148.5
It looks that the driver is not fully compatible with Windows 10
Is there a solution ???
Greetings Albert
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi albert1946,
    Try installing the standalone driver instead of the Genie version.
    JamesGL
    Community Team
    • albert1946's avatar
      albert1946
      Hi
      Thanks for your answer, I'll try the standalone version and will see what the computer will do
      Greetings Albert
      • JamesGL's avatar
        JamesGL
        Hi albert1946,
        We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
        If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
        JamesGL
        Community Team
