David14712's avatar
David14712
Follower
Mar 02, 2017
WNA3100 wifi upgrade help please
I am currently using the WNA3100 wifi adapter and I have recently started having lag issues while doing some gaming. Since wifi is my only option for internet connection I thought I would look into upgrading my wifi adapter to have better internet performance. One adapter I was looking at was the N900 because of its higher speed. One thing that confused me about it was that it says the speed is 450 + 450, can anyone explain that to me? thanks. I was also looking at the AC1200. I will be playing games such as Battlefield 4 and Tom clancys ghost recon with it if that helps. Does anyone know which wifi adapter would be better for me or can reccomend one that is good for wifi gaming? Thanks much appreciated
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi David14712,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
