Budgie4
Nov 29, 2016Tutor
WNCE4004 How can I change the static IP
I do not have WPS so followed the instructions for installation without WPS.
Problem is that the device has a fixed IP (192.168.1.240) and therefore I have to set lan address on my pc to same subnet so I can talk to the device.
Followed all the instructions and set device up for my existing wifi AP which is on a different subnet. Once I apply the settings I lose connection to the device. At no point in the proceedings am I given a chance to change the fixed IP or "default" IP, so my first question is;-
How may I change the fixed "default" IP so that the device is accessible on my lan subnet?
Better, Is there any way I can get round the dreadful (evil) Genie and use a dumb browser interface?
Best, Can I SSL or Telnet into the device and do it all on CLI?
- JamesGLNETGEAR Employee Retired
Hi Budgie4,
The IP should change if it is connected already to the AP. The fixed IP is just the IP of the adapter for initial installation. No need to to set a static IP on your computer since the adapter will provide IP for initial configuration.
JamesGL
Community Team - JamesGLNETGEAR Employee Retired
Hi Budgie4,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team- Budgie4TutorHi James and thanks for the follow up. I am not yet able to confirm all is well. I am still trying to diagnose a problem which is not, I trust, due to WNCE4004 but by fixing its IP address in band I want to remove one of the uncertainties so hopefully I can pin down problem. Will post again when hopefully I have solved the problem. Thanks again. Budgie
Hi Budgie4,
Any updates on your issue?
JamesGL
Community Team
