n4hmr
Dec 23, 2015Aspirant
WNDA4100 Install on Win7 Ultimate; Genie Won't Run and No Speed Increase
I just recently bought two WNDA4100's to replace a couple of WNA3100's on two Win7 Ultimate PCs. I was looking for higher download speeds.
Issue #1. When I had the WNA3100's installed, Netgear Genie worked just fine - every time. After I removed the WNA3100 install and installed the WNDA4100 (V 1.2.0.14), Genie blew out shortly after cranking up for the first time with the message "WNDA4100 Genie MFC Application has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." Didn't even get a chance to use Genie to select the Dang network. I used the Windows screens to get the 4100's working.
Now, even thought the Genie icon is on the Desktop, I have to click on it MANY times to even get it to launch; sometimes I just see a quick flash in the center of the screen then its gone or just see a 'busy circle' over the icon with no further indication. If it does put the Genie screen up, I immediately get the failure message mentioned above. Same thing on the other PC.
What's bugging BOTH PCs? Note: Didn't have this Crap with the WNA3100 installs.
Issue #2
After using the Windows screens to select the Network and enter the Security code, I am not seeing any speed increase at all! Not happy! Both PCs are Dells - a GX520 and a 755 USFF (4Gb each). The 755 is clearly more powerful than the GX520 but no speed increase on it either.
My ISP is TWC, and I have a TWC Arris modem to feed the voice line, and I use my own Motorola SBG6560 for the Internet operation. The 6580 is running in N mode, so why don't I get better speeds
- n4hmrAspirant
Forgot to mention that the two PCs are about 15' from the 6580, and I still have full power showing with the 6580 cut back to 75% power.
Fred
- pescoAspirant
Similar situation here. 3100 drivers and software removed prior to new installation. All goes well until asked to connect the 4100 then APPCRASH
Problem signature:
Problem Event Name: APPCRASH
Application Name: WNDA4100.EXE
Application Version: 1.2.0.10
Application Timestamp: 50ecd160
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.19045
Fault Module Timestamp: 56258f05
Exception Code: e06d7363
Exception Offset: 0000c42d
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789Feedback / advice would be welcomed
- n4hmrAspirant
Hey Pesco -
Sorry to hear you're having this problem, but at least now I know that SOMEBODY else has it, too!
Two very important details missing in your post is WHERE did you get the file you tried to install, and what version of the file were you using? Read on for more info!
I have been working with 2nd Level Tech Jenny (and others) on this problem. I've been in and out a lot so have had difficulty re-connecting with Jenny. On 01/04 (I think), Jenny said she went to the lab and downloaded a *Version 1.2 0.14* file and installed it. She reported that it worked just fine, ***AND*** that the Genie screen reported that the Genie version was *1.2.0.14*!
Me and the Techs I have worked with have REPEATEDLY (15-20 times) downloaded the v 1.2.0.14 file from the website, AND EVERY TIME IT BLOWS OUT FOR THE GENIE APP! *FURTHER*, it reports the Genie app version as being *1.2 0.10*, just like you reported, NOT THE v1.2.0.14 THAT JENNY SAID SHE SAW IN THE LAB!
I have been trying to get Jenny to grab the file she used and transfer that file to me using TeamViewer. I want HER file to test here - since she said it worked in the lab and gave the matching Genie version number (1.2.0.14)!
I am waiting on a call now from Jenny, and hopefully I'll get HER version of the file. We'll see.
Fred
- DanT2590Tutor
Having the exact same problem with the 3100's on both Windows 10 computers. Does exactly the same thing. Never runs!
