Vsmoove
Mar 19, 2017Follower
AC1900 Doesn't Connect to 5ghz
Hi, my AC1900 randomly stopped connecting to my 5ghz Uverse router. The 2ghz works perfectly and I've reset the router and extender several times. After every full re-set the 5ghz works for some perio...
DarrenM
Mar 21, 2017Sr. NETGEAR Moderator
Hello Vsmoove
I would check the fastlane settings on the extender make sure that is not the issue if not you may want to contact support.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
