fastphil1968
Dec 08, 2017Follower
Ac750 dual band wifi range extender
I have plugged this in i get a power light but can't get it to connect to my existing wifi. I have pressed the wps button on the extender and on my router it blinks green but doesn't connect If I go...
DarrenM
Dec 12, 2017Sr. NETGEAR Moderator
Hello Fastphil1968
Try to factory reset the extender by holding the reset button for 10+ seconds then try those connections methods again.
DarrenM
