Northflboy's avatar
Northflboy
Ac750 WiFi EX6100v2 range extender
Set up went fine. Instructions say to enter the same password you do for your home router. When I do that, it won’t connect. Any advice?
  • Hi Northflboy,
                              Please check the password of your router as it is case sensitive and your extender can connect to it only if you enter the correct password. If you are entering the correct password and if you still encounter the same issue, please skip the setup and check for firmware upgrade if any, do manual update and try running the setup again.
      • jvasanth1984's avatar
        jvasanth1984
        Virtuoso
        Hi Northflboy,
                                 Did you skipped the setup and tried looking for firmware upgrade if any?
