cdysthe
Oct 09, 2016Virtuoso
Adding an ex7000 to my r7000 with smart connect enabled.
Hi, I am currently using a r7000 with smart connect enabled. I know some of you do not like smart connect, but it works fine here and makes it easy for users. I am about to add an ex7000 and was ...
cdysthe
Oct 17, 2016Virtuoso
Thanks, I do not have a problem setting up the EX7000. The question was how it would affect my setup that the R7000 is set up with Smart Connect which means same SSID for both 2.5 and 5 GHz bands. I have experimented with it a little and found that it works fine here with only one SSID across my whole house.,
