Ironmonger
Sep 10, 2020Tutor
Appalling Support
Hi, Has anyone else experienced the same level of appalling customer support that I’m enduring in trying to replace a faulty extender? I bought an EX7700 on 19 Aug. That device caused anything conne...
Sep 10, 2020Guru - Experienced User
What router are you connecting it to?
What firmware is on the extender?
Are you attempting to set it up using the wps method?
