mystichead's avatar
mystichead
Initiate
Jun 11, 2016
Can Access Point mode in Ex6150 take the signal from router wirelessly or does it have to be wired
Hi guys,   I was wondering if the 2 EX6150 Range Extenders I have can be set up as Access points while connecting to the router via wireless, maybe even connecting to the router via 5GHz band and ...
  • TheEther's avatar
    Jun 12, 2016
    Access Point mode on the EX6150 requires a wired connection back to the router.
    Just run the EX6150 in extender mode.  It's not as efficient as Access Point mode, but it'll do exactly what you need.
