knguyen555's avatar
knguyen555
Follower
Apr 08, 2016
Can you use 2 wifi extenders at the same time?
Can you use multiple wifi extenders?
Hello there, I just purchased a Wi-Fi extender 7000 and it works great downstairs but the signal is weak upstairs. My question is if I bought another wifi extender the same one EX7000 can i use both of them at the same time or will having the same network extension make it conflict? Thank you in advance.
Editors Note:
Solved: Yes you can use 2 extenders at the same time, with some caveats - read on for more details. You may also consider a WiFi 6 Range Extender or a WiFi Mesh System such as Orbi for stronger signals and more WiFi range and flexibility.
  • Yes, you can use 2 extenders with a few caveats.
    1. Do not wirelessly connect one extender to another.  Performance for the second extender will usually be unsatisfactory.  Therefore, each extender should connect to the main router.
    2. Both extenders should not broadcast the same SSID as the main router.  This is the default setting but many people often set up an extender to broadcast the same SSID to avoid programming devices with two separate SSIDs.  You won't be able to do this with two extenders because there is a risk of them connecting to each other instead of the main router.  This restriction doesn't apply if you are able to wire the extenders to the main router via Ethernet (or Powerline).
  • I have a similar problem as shown above, I can connect to my first EX7700, but not the other (right next to my router.  I verified latest firmware version, did a factory reset, but can only connect to the first extender via WPS or the app.  In the App, see both extenders (connected to my R9000), but one of the extenders shows up as a white box rather than the icon.
    Any tips or pointers would be appreciated.
    /RW
    • olympos1625's avatar
      olympos1625
      NETGEAR Employee Retired
      Hi @Rixter6969,
      Thank you for reaching out. How are the 2 extenders connected o the R9000 router? Are the 2 extenders configured as wireless extenders or access points? Did you try turning off the working extender and just have the 1 extender( affected) connect to the main router and see if it behaves the same?
      I am looking forward to your response.
      Oliver
      Community Team
  • Yes, you can use 2 extenders with a few caveats. Do not wirelessly connect one extender to another. Performance for the second extender will usually be unsatisfactory. Therefore, each extender should connect to the main router.
    • ihawk's avatar
      ihawk
      Tutor
      You can, I have 3 extenders. 1 connected to the main 1 router and 2 daisy chained off with no loss of signal or traffic flow
      • StephenB's avatar
        If you aren't using fastlane with a triband extender, then there will be a loss of throughput.  However, your bottleneck might be your internet connection speed, and not your wifi.
  • I installed the AC1200 and it works great. I need to add another extender at the other end of the house and purchased the AC1900 arriving tomorrow.  The AC1200 automatically appended _2G, _5G, _2GEXT and _5GEXT to the primary network name. So, there are 5 networks to choose from. Will I have to configure anything special in order to use both extenders?  Will the network names be duplicated automatically or will I be able to distinguish between the AC1200 and AC1900 networks?
  • found that my house are not suitable to use wifi extender as there are too many inteference
    i end up getting power line adapter and setup 2nd router as access point on 2nd floor
    now i have excellent wifi signal cover whole house
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello blnh
      Yes you can and you will want each extender to connect directly to the routers wifi network also you may need to rename the SSID on the new extender in setup to cause less issues.
      DarrenM
      • Dalton89's avatar
        Dalton89
        Ok so if I connect them both to the main router then how does that make the signal reach further? Wouldn't one have to be hooked up to the main one and extended to the proper length away and then the second one hooked to the first one that is hooked into the main one that is sending the signal out? I'm not sure I understand because the booster I have is and has to be completely wireless. So here is the situation.... My kid lives across the street and a house over and we're sharing wifi (and the bill of course lol) and I bought the first booster and set it up at the best length away from the main router and he gets wifi not but only in the bathroom and the closest room to the street and only at half signal. So if I buy another one can I wirelessly connect them in the order of the main one then the first booster into that and then the 2nd booster into the first booster to maximize the signals reach? And without slowing the speed?
    • Meoper's avatar
      Meoper
      I have the ex 7000. Can I add the ex 8000 and use the same name on both?  Thanks.
      • DarrenM's avatar
        DarrenM
        Yes the ex8000 will allow you to use the same SSID.
        DarrenM
    • Gregory1234's avatar
      Gregory1234
      Initiate
      Hey .. I has a simple qu on multiple (three units, on multi story villa) ACCESS POINTS (with these EX7000 Range Extenders with cables back to the master modem) .. when I set up each unit (EX7000) the Setup Wizard makes me enter a NEW ACCOUNT (email & pword).
      Can I use the same one each time, or do I need to use 3 different emails??
      Maybe I have to turn off the 1st Unit I setup & then setup & login to the next one separately (but with the same email ??)
    • sxx's avatar
      sxx
      I'm already using one EX7000 connected to a router thru RJ45 in a multiple floor building...
      Is it possible to connect a second EX7000 to the first EX7000 thru RJ45 instead of a direct connection to the main router?
    • Alaind's avatar
      Alaind
      Initiate
      Great answer, thanks !
      I understand the second Extender needs a different SSID but how do I do that ?
