SPlatten's avatar
Feb 09, 2020
Cannot connect , password not accepted
I purchased an AC1200 Dual Band WiFi Range Extender.  I followed the instructions as per the Quick Start guide and I have solid green lights on  Power, Router and WPS LED's.
On my iMAC I can see two new additions to the WiFi network, one ends with _5GEXT and the other _2GEXT.  When I try to connect to either of these networks I am prompted for a password.  I've entered my WiFi password and verified that the password is correct in my router set-up.
Despite this I cannot get connected.  After a short delay same password dialog is displayed again.
What I am not doing?
  • Just making sure its clear as I re-read mine and was a bit confused :)
    If you haven't set it up yet, the wireless ssid/password should be printed on the device. Use that to connect to the extender and then go through the setup process. You can custom set the ssid/password for the extender while going through the setup process.
  • plemans's avatar
    Did you try setting up with the smart connection wizard? Not all manufacturers implement wps the same.
    What router are you connecting to?
    Firmware on your extender?
