atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
sgillas
Nov 20, 2016Aspirant
I am having this problem too. I am trying to connect to a R6100.
This also fails to manintain a connection even at non-5G, in the SAME room. I have over a dozen devices all on either normal or 5G in house working fine, so it's not the router...
I see this has been an ongoing support issue for years with little/no support from Netgear. I purchased this one in particular to make things "easy" since my router was netgear. But, alas no. So, thanks to Amazon Prime, it goes back and I switch maufacturers....
~ Shawn
