atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
atkinsonline
In order to try to eliminate any unknowns, I have just factory reset both the 2500 and the 3700 and I get the same problem. 2500 connects at 2.4 but refuses to connect at 5GHz. Fails whether I use WPS or the web interface
John.
John.
