atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bentanvil
May 31, 2012Tutor
Hardware Version DGND3700
Firmware Version V1.0.0.17_1.0.17
Hardware Version WN2500RP
Firmware Version V1.0.0.26_1.0.54
I have both the router and the extender currently in the same room. The extender is picking up a signal strength of 94% for 2.4GHz and 82% for 5GHz from the router.
With my ipad I can connect to all 4 wireless networks
I have done factory resets on both devices to no avail. I have removed all security from the router and still can only get the 2.4GHz to connect. I have now tried WPA2-PSK (AES) with different passwords on both networks but still nothing on the 5GHz.
