atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bentanvil
May 31, 2012Tutor
UPDATE: I have just done another factory reset to both devices and with no wireless security on I have been able to get the extender to connect to both bands. I will now try the process of elimination on the different securities.
