atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
Scubbie
May 31, 2012Apprentice
Ok, you have the latest full release firmware on the DGND3700. There are some Beta versions available if you want to contact Tech support.
I wonder if it is because of the WPA/WPA2 licensing issues? Just for the purposes of testing, could you disable the WiFi security and try connecting the two that way?
As for the signal strength, the difference is normal. Something to do with the way 2.4GHz and 5GHz work, essentially when pumping out both at the same strength, 5GHz will drop off before the 2,4GHz signal.
