atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bentanvil
May 31, 2012Tutor
So I just changed the 2.4Ghz security to WPA2-PSK (AES) and I lost the connection. 5GHz stayed connected fine.
I am now going to follow your suggestion and see if WEP works.
If I can't use WPA2-PSK (AES) to connect the 2 devices I feel that these products are pretty useless together and that NETGEAR has lead me up the garden path.
