atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
Scubbie
May 31, 2012Apprentice
bentanvil wrote: So I just changed the 2.4Ghz security to WPA2-PSK (AES) and I lost the connection. 5GHz stayed connected fine...
Just a small point, as I am loosing track a little. I though that you only needed either the 5GHz of 2.4Ghz to connect the DGND3700 and WN2500RP together. Unless you have specifically notice an improvement in throughput if both are connected simultaneously.
Are you able to connect to the WN2500RP using both the 2.4GHz and 5GHz all the time?
