atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bentanvil
May 31, 2012Tutor
Right, I can't even connect using WEP. The only way I can now get the 2 devices to talk to each other is with NO security. No ideal at all.
Any other ideas Scubbie? Thanks for your advice so far! :)
