atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bentanvil
May 31, 2012Tutor
Scubbie wrote: The only other ideas I have are non-Netgear firmware and using a long length of Ethernet Cable. HomePlugs are fine, but most are limited to 200mb or 500mb and you have a 1Gbit LAN on the DGND3700.
The long term plan is to get a sparkie in to wire the house but that is probably a long way off.
Scubbie wrote: During one RMA swap I attempted to connect the two DGND3700s that I have via WiFi and it was then that I found out the WPA2 didn't work. When I next communicated with Netgear I asked about it and it was confirmed that it had to be either WEP or no security.
Luckily I am out in the country so having no security isn't a major issue, just not preferred. I could use an ACL for wireless devices making it a little more secure than nothing at all. Did NETGEAR say if they are going to release a firmware upgrade to fix their issue with WPA2? Is it limited to the use of dual bands only? Bit of a cheek calling it a Dual Band Extender. They should call it a Unsecured Or If You Want A Little Security Expect To Have Slow Bitrate Speeds Dual Band Extender
