atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
Scubbie
May 31, 2012Apprentice
The access list would make it harder to log in, but any transmissions could be easily read, so I hope that you don't send any private stuff via the WiFi.
I got the impression that the WPA/WPA2 issue was to do with the router not the AP or Extenders. There are custom firmwares available for the DGND3700 now. I haven't played with them so I don't know if they would be of use to yourself.
The one I am thinking of (DG-WRT) is normally only for cable routers. This might not be suitable if you are using an ADSL connection.
